Sycles 2.1.3
This is a typical effect for any ray-tracer renderers. It appears for low-poly objects with smooth shading. There is shadow terminator property (in Cycles Mesh property). It helps to resolve this render error.
Okay, thanks for the info...
...so much to learn still after all these years...
Great!
The word "static" is used, but it is theoretically possible to turn visibility on and off, isn't it?
Maybe in the future sequential reading will no longer be a dream!?
Luckily I spoke too soon... I removed my previous post.
Sorry for the noise, I was extremely frustrated.
A system reinstall seems to have fixed the problem
I was having with Sycles not rendering with CUDA at all...
Still crashes on activating Optix though.
There are many possible reasons for crashes. May be some error with OptiX driver, or bug in the Cycles render engine. Try to select only one OptiX render device in the render settings. Is it still crash? Also try to render in the Blender some simple scene with selected OptiX device. May be the Blender will be crashed too. Then we can only wait, when Blender developers will fix it.
- wireframex
Hi
Just tried rendering with Optix GPU without any pb only if I uncheck CPU option
EDIT : the gain is about 40-45% with Optix GPU rendering mode (compared with normal GPU mode without CPU)
Greetings, long time lurker de-cloaking :]
Apologies if this has been asked already or if it's a dumb question - Is there any way to get this to work in XSI 7.01? (I never bothered upgrading after adesk took over).
It seems to install without any errors but does not appear in the renderer selection drop menu.
No, it's imposiible. Because there are some changes in API between XSI 7 and Softimage 2015.
Hi, how can I transfer color attributes from an ICE particle "Randomize Color" on an object using cycAttribute? I've tried setting the emission material and attached a log node to the output of the randomize color, but no matter what value I type in cycAttribute nothing gets rendered. Any ideas?
Thank you
Thank you
You mean you can replicate the example in the document, with a meshI3D wrote: ↑29 Oct 2020, 05:03 Hi, how can I transfer color attributes from an ICE particle "Randomize Color" on an object using cycAttribute? I've tried setting the emission material and attached a log node to the output of the randomize color, but no matter what value I type in cycAttribute nothing gets rendered. Any ideas?
Thank you
But can not make the same setup working with particle points ?
I believe "density" is a per object data, like in Sycles with emFluid
So cycAttribute won't working with per point data?
Sycles does not render particles. It can render only mesh instances instead of these particles. To use points attributes in the shader of the mesh instances, you should add to the pointcloud object CyclesPointcloud property and turn on the parameter "Use Pointcloud Attributes for Instances". This is a screen with an example:
Material with cycAttribute node is the material of the instance object. The material of the pointcloud does not matter.
- sirdavid32
Thank you for sharing this Shekn, this goes a long way how to integrate Softimage and Cycles with an ICE mindset. It's impressive, to say the least.
Web: http://www.3dcinetv.com
Thanks Shekn, that is exactly what I was looking for.
Hi opoppopoppopoppopopp wrote: ↑29 Oct 2020, 16:56 You mean you can replicate the example in the document, with a mesh
No I wanted to render instanced geometry from a particle animation, I was able to do so, however the randomize color attributes wasn't being rendered on the instanced meshes. But Shekn response resolved it.
It shouldn't render particle shape? or just I am miss understanding.Shekn wrote: ↑29 Oct 2020, 18:34 Sycles does not render particles. It can render only mesh instances instead of these particles. To use points attributes in the shader of the mesh instances, you should add to the pointcloud object CyclesPointcloud property and turn on the parameter "Use Pointcloud Attributes for Instances". This is a screen with an example:
of course 'blob' shape not working, but others seems ok?
When you render particles with (for example) a cube shape, then the renderer crates a polygonal abstract cube and use it as an instance for particles. The same for spheres, cones and so on. Exceptions are only point and blob shapes. Because it is not polygonal objects. So, these particles are also instances. And yes, for these primitive shapes, the render use material of the pointcloud (because there is no real object for it), but for user defined instance shapes it use the material from the master object.
