Hello. I have an issue. Softimage is known very stabile but it crashes when modeling. I think that this comes because the addons I have. Softimage version 2015/ I'm using a tablet.
Does switch to early version solve this issue? Or how to fix?
Softimage crashes when modeling
- wireframex
Re: Softimage crashes when modeling
Just remove all your add-ons and test SI alone
If it works then go to next step below if it doesn't work maybe a software problem --> Reinstall.
Install each add-on one by one and test each time with SI. You will find the add-on problem.
Since crashes come randomly it's not easy to test everithing.
Yes I have tested and reinstalled XSI. I tested it even on another computers.
I think the number of crashes is been reduced since I uninstalled some addons that affect viewport like "QuickInset". But sometimes crashes still appear.
Do you know which addons are certainly unstabile and make crashes? I could start testing from them.
- wireframex
I don't have particular instability problem with SI and have many add-ons / plugins :
AddOverrides
AppLink_3DCoat
BasicRuler
BevelCurve
CM_DefaultPrimitives
CurveRibbon
Dafeng_Renamer_EN
EasyExploring
emFlock2
emFluid4
emFluid5
emNewton2
emPolygonizer5
emReader
emRPC4
emTools
emTopolizer2
emTree
EssGeo
ET_PassManager_v3.0
ET_SchematicTools
FFill
FXNut_TautOp
GoZ
HDRMaster
kCS_IceRuler
keyvisCurveTools
mAligner
mCleaner
mCombinePolygons
mHardEdgeMarker
MotionTools
MoveNormalAddon
ms_xsiShatter_v4-1
ms_xsiWire_v1-0
mSeparatePolygons
mTextureEditor
MX_4Sided_v1.0
MX_CurveDeform_V.1.0_pre_release
MX_CurveTools_1.0_XSI7.5
MX_Loft_2_v1.0
MX_Roundish v1.0
NormalAlign
pmMeshPaint
pmQuickExtrude
pmQuickPrimitive
pmSoftTransform
PowerExtrude
quickThickness
rcTools
ScatterTools
ScriptEd
SelectionSets_v.2.0
SlipstreamVX
Species 1.6
SPH
ss_SelectSimilarPolys
SToon
Sycles
T_Gen2
TR_Extract
WeightedNormals
whGear
AddOverrides
AppLink_3DCoat
BasicRuler
BevelCurve
CurveRibbon
Dafeng_Renamer_EN
EasyExploring
emFlock2
emFluid4
emFluid5
emNewton2
emPolygonizer5
emReader
emRPC4
emTools
emTopolizer2
emTree
EssGeo
ET_PassManager_v3.0
ET_SchematicTools
FFill
FXNut_TautOp
GoZ
HDRMaster
kCS_IceRuler
keyvisCurveTools
mAligner
mCleaner
mCombinePolygons
mHardEdgeMarker
MotionTools
MoveNormalAddon
ms_xsiShatter_v4-1
ms_xsiWire_v1-0
mSeparatePolygons
mTextureEditor
MX_4Sided_v1.0
MX_Loft_2_v1.0
MX_Roundish v1.0
NormalAlign
pmMeshPaint
pmQuickExtrude
pmQuickPrimitive
pmSoftTransform
PowerExtrude
quickThickness
rcTools
ScatterTools
ScriptEd
SelectionSets_v.2.0
SlipstreamVX
Species 1.6
SPH
SToon
Sycles
T_Gen2
TR_Extract
WeightedNormals
whGear
My plugins folder is even simplier.
Did you notice that some of plugins are not campatible when have both of them installed? Especially those ones that interact in viewport. Like slice knife, smooth loop and many others. The only that I left is six point aligh.
By the way does bridge to 3DCoat work? It's outdated
- 1111.png (5.83 KiB) Viewed 11688 times
the bridge to 3dcoat does work, as I have 3dcoat 4.9
I know ... right ?wireframex wrote: ↑09 Dec 2021, 19:19 I don't have particular instability problem with SI and have many add-ons / plugins :
Users browsing this forum: trendiction [Bot] and 47 guests
