QuickThickness
QuickThickness
This addon which adds thickness to the surface layer of a polygon mesh. Compared to
existing solutions like the built-in push or InteractiveThickness, it offers some
enhancements: multiple selection
progress bar multi inspect parameters invert normals if value is negative Doesn
local backup: quickThickness_v1.6.xsiaddon
author's youtube channel / si-community thread
Re: QuickThickness
can you capture logs in script editor ?
maybe you try select poly ? but you need selection object
- wireframex
Re: QuickThickness
I select object then I select the tool in "modify/Poly.mesh/QuickThickness" --> the result : all polys are inverted and selected and nothing elseeistan wrote:wireframex
In the script editor :
Application.SelectObj("cube", "", True)
Application.QuickThickness()
Application.SelectFilter("Polygon")
Re: QuickThickness
I had that same thing happen while I was using it yesterday, and I think it was because prior to running his tool, I already had an 'invert normals' op on the mesh. I froze modeling and tried again and it was fine.
- wireframex
Re: QuickThickness
I tried the same but it doesn't work ....El Burritoh wrote:I already had an 'invert normals' op on the mesh. I froze modeling and tried again and it was fine.
Re: QuickThickness
try this
btw its new version where i added Freeze button, it means freeze objects and close the window
try this
- wireframex
Re: QuickThickness
Thanks a loteistan wrote:wireframex
try this
I will test this next wenesday
Phil
Re: QuickThickness
and my new plugin in development, but i dont know why im doing it =) xsi users there are very few ((
Re: QuickThickness
True. They are however generally very gratefuleistan wrote:and my new plugin in development, but i dont know why im doing it =) xsi users there are very few ((
- wireframex
Re: QuickThickness
Hieistan wrote:wireframex
try this
I have the same message than before : "OLE Error 0x80020101"
Softimage 2012 x64 SP1
All the best
Phil
- wireframex
Re: QuickThickness
I'm sure there is more users than you thinkeistan wrote:and my new plugin in development, but i dont know why im doing it =) xsi users there are very few ((
I sold my C4D Studio R16 licence few weeks ago ... Prefer stick with SI
All the best
Phil
Re: QuickThickness
It looks useful eistan.
- wireframex
Re: QuickThickness
You were completly right I had a pb with Python I just remove and install the last version ... Now it worksHirazi Blue wrote:Did 2012 already "ship" with its own preinstalled Python ? If not you should install Python and pywin32 first... ;)
Thank you
Phil
Re: QuickThickness
When trying to undo after using this plugin this happens. Clicking undo for 20 times is not fun
https://www.dropbox.com/scl/fi/9ztlmiua ... krula&dl=0
Users browsing this forum: brandwatch [Bot] and 54 guests
