Hi There!
I have a question on ICE and Vector.
I'll try to create a Vector from the difference between the position of one vector/geometry with another to drive the direction of my particles.
If I do it on the grid works, but if I try to use it inside the ICE Tree Simulation with particles doesn't work...
I try to do the same I did here with scripting in VEX (Houdini)
Thanks for your help
Matteo
Create a Vector from a diffent a position between 2 objects
Re: Create a Vector from a diffent a position between 2 objects
Hi, first I added a "Switch Context" node ( required for getting stuff from other objects )
but what I think made it work was getting the point positions of the grid nearest to the particle
Then you can use it to set point velocity,
or you can also use the vector to set initial direction
( also set the direction dropdown in the Emit compound PPG to "Use initial direction")
Is that what you were looking for ?
best,
best,
first, thanks, works, but I don't understand why is working differently for the geometry.FXDude wrote: ↑19 Jan 2024, 17:44 Hi, first I added a "Switch Context" node ( required for getting stuff from other objects )
best,
I tried also to apply a "negate" operator, but not did do what I wanted, maybe I should use "additional" and not subtract in this case?
But yes, it seems strange on the geometry I have one result, and on the particles another... I should investigate more.
I wasn't sure if the shown vectors or Ice trees were from the mesh or the PointCloud,
and were these visualized vectors in the default "vector trails" mode ?
Also, first I thought you wanted to set the direction and perhaps velocity of particles, and maybe it was ?
( the closer is the sphere to the grid, the slower is the velocity of emitted particles )
Otherwise, about negating vectors, switching subtraction order is the same as negating after,
and in the following I used whichever order that matched your Houdini clip visually
I also used the "Set Normal" compound from EM-topololizer to set the "UserNormals" attribute,
( overrides native normals for non-subD-ed meshes )
So both the grid and the asteroid get their normal orientation from the closest point on the animated sphere
and then the cone particles get the resulting "userNormals" attribute from the "asteroid" to set their orientations.
I used normals, because that's what was shown in your presentation,
( if it was important, and to show that it could be done )
but we could also have have set an arbitrary vector attribute , and get that instead of the "UserNormals".
PointCloud Tree
"Adteroid" tree
bumpy sphere with same tree in the Sim as in the Modeling Stack, otherwise UserNormals would not update in time
And here's the scene if you want,
https://www.dropbox.com/scl/fi/k4vrryci ... 2wyjz&dl=1
and let me know how that fits !
Cheers,
PointCloud Tree
"Adteroid" tree
Cheers,
Thanks a LOT!
I check it soon
Matteo
I check it soon
Matteo
