Kristinka Hair 2.0
Re: Kristinka Hair 2.0
OMG u are amazing!
thank u!!
I will give a shot once i have time back to my stuff!!!
thank u!!
This looks ace. Thankyou very much for your hard work and generosity.
I look forward to having a crack at learning it.
Ah, a true christmas present...
Thank you "Santa" Mathaeus
Awesome!Thanks! Going to check them out very soon.
Could you expand further on how to transfer strand color to the rendered shader? Thanks.
you call color attribute in render tree ('attributtes' nodes...), I think sample called 'MT-Extrude-Transfer-Color' already has Rendertree setup. Color attribute need to be created in ICE tree, in some way.izze wrote:Could you expand further on how to transfer strand color to the rendered shader? Thanks.
Thank you again for your help. I missed the sample scene. Sorry.
A question, is it possible to UV map the resulting mesh?
Of course
I think it's explained a few post above. There are a few compounds just for that.
Basically there two methods:
1. compound called 'Set UVs On MT Extrusion' (or something similar). First you set some UVs on MT extrusion, then ICE node re-arranges UVs. This one is working on stripes only.
2. compound called 'Create Cylinders From MT Extrusion', that fits the mesh into one or more vertical cylinders or stripes (according to subdivision count), so you an set UVs in your own way.
Plus a few 'utility' nodes for 'sticking' mesh to Point Cloud (if mesh is frozen, so there is no Helge's operator on it anymore), reverse of that, depending on what you need.
For now, limitation is that point cloud need to have 'uniform' strand array, same count of segments for each strand (no 'Optimize strand' , node), also, once the mesh is frozen, Point Cloud should keep the 'topology' - same count of points and segments, as well as same topology on mesh . Nodes were built on simple, but relative fast math (modulo, divide by scalar, so on), that does 'remapping' of IDs from strands to mesh, or reverse.
Sorry guys the queston, but I have to solve urgent issues, and that's why I'm asking. Technically I'd like to make hair with Kristinka for games, using poly strips.
The next question is that how I use the collision mesh? I have guide hairs that penetrates into the head of the character....
'collision mesh' name, is actually a heritage from some early versions. In a few last versions, no one node is using this. However, there is a chance you can find compound called 'Push strands outside geo' (or something like...) in Helge's stuff (Melena or MT-strands..). As name says, this only moves strands outside of *closest* polygons.
If interpenetration happens only on hair filler, and you're using Follow NURBS node on guides, probably you can fix this by moving 'Split on Y' slider at bottom of PPG.
Good luck
Good luck
Thanks I need it...unfortunately I couldn't found the above mentioned compound....
The link to the last "known" version of the MT_StrandNodes addon can be found in this thread
This addon contains the "Push Strands Outside Geo.xsicompound" Mathaeus mentions above...
Jester,
if you could describe a bit more what actually happens, would be nice. Effect of mentioned compound depends on closest surface. If strands are somewhere in the middle, there is a chance segments will 'spread' all around. Btw, 'Test collision with surface' inside 'Strand dynamic framework' is pretty much the same thing.
a few questions
Polystrips - I've been playing with the extrusion compounds for a while, but I'm having trouble setting up the uv's on the extruded geo. Does anyone have a tut, or ice tree they could show? I'm interested in the strips of poly's rather than the cylindrical, but any help would be great.
I'd ultimately like to rendermap (or ultimap?) kh hair to a low poly mesh, or the extrusions themselves - has anyone done this? my maps come out all black (but that may be my error on setting up those ops...)
Density - I noticed the remap uv's for emitter mesh. is this how you guys are getting density for hair at the hair line on forehead (in the hair test thread)? I know there is a way to use something like this or fcurve for controling density (rate?). I've set the density controls on the emit hair compound and I can increase the density around the forehead, but when looking straight on at a character, its scalp is still visible. how many strands are being emitted in the girls hair on bottom of page 4 (anto's)?
Thanks for sharing this set of compounds! its great stuff.
hi there
- uv on poly strips: I think simplest way is just to freeze mesh, apply (to mesh) node called 'Create cylinders from MT extrusion' (actually it creates the straight strips too, name is a bit stupid), freeze it again, create your UVs, then apply node called 'stick MT extrusion to point cloud' - this will fit the mesh back into original shape
- render mapping, probably you need to set distance to surface to something higher than distance from mesh to last 'hair' - if you're rendermapping the emitter (head)
- for hair 'interface' line, a 'nice' way is to gradually delete some strands ('kh delete points', driven by weight map on emitter, plugged into 'execute on emit' of kh Emit Hair. However, girl on page 4, that's just erased in post (hair was rendered in separate pass)
- about 30k hairs for girl on page 4, about 70 segments.'Rendering weight' is count of hairs * count of segments, so long hair costs much more. Together with small rendering strategy (fixed 32 pixel tile size with rasterizer, pre-rendered FG map, fixed rendering 'depth' level to about 20 , otherwise MR falls into lovely 'trace additional FG points', forever). Hopefully you can use 3delight now.
