Page 5 of 7
Re: mesh paint
Posted: 16 Sep 2012, 16:57
by origin
yashugan, you need to be more specific, image of what you want to achieve would be helpful.
Re: mesh paint
Posted: 16 Sep 2012, 20:23
by yashugan
Excuse me for my incompelte question.
I explain better:)
I trying to paint rows of objects, but the rows still randomize the position of the objects. I saw in a vimeo video that you painted bullets on a airplane, and the bullets where regular and not randomized. How i can do it? I putted all ZERO value in the randomize window. where i'mdoing a mistake? Thank you!!!!!!!!!
Re: mesh paint
Posted: 16 Sep 2012, 20:27
by origin
Just scale the brush radius to 0 (r+lmb and drag)
Re: mesh paint
Posted: 16 Sep 2012, 20:50
by yashugan
yeah!!!!!!!!! thank you!!!!!!!!!! simply amazing tool!!!
Just a question, that i'm here: do you have intention to release also the plug in to move textures UV from the mesh? Ishould be a revolution....
thank you!
Re: mesh paint
Posted: 19 Sep 2012, 21:22
by ActionArt
origin wrote:Just scale the brush radius to 0 (r+lmb and drag)
For some reason this isn't working for me. I can't seem to scale the brush.
Anyone else run into this? Perhaps it's a preference setting or something?
Re: mesh paint
Posted: 19 Sep 2012, 22:57
by Kerro Perro
You're not pressing left and right mouse button at the same time are you?
Maybe a silly question but the line you quoted kinda reads that way...
Re: mesh paint
Posted: 19 Sep 2012, 23:01
by origin
key R+ left mouse button, like the si tweak tool, should work...
Re: mesh paint
Posted: 19 Sep 2012, 23:16
by ActionArt
Ah, not a silly question, silly me. That's what I was doing
Works fine, thanks!
Re: mesh paint
Posted: 20 Sep 2012, 07:33
by ActionArt
I'd just like to say, that is one sweet tool! Your best so far IMO. I've been trying it all evening and works perfectly so far.
Like I said, I have just the project waiting for it. Will start on it tomorrow!
Thanks a million!
Re: mesh paint
Posted: 20 Sep 2012, 08:22
by yashugan
I'm using you tool in these days and it saved to me a lot of time placing trees in the scene! is amazing, thank you again!
Super cool tool.
Re: mesh paint
Posted: 03 Dec 2012, 12:29
by uhans
sorry but can you halp me to finde the tool meshpaint ? sorry for this primetive question !!!
Re: mesh paint
Posted: 03 Dec 2012, 12:44
by Rork
the download links are on the first page. Don't they work for you??
Re: mesh paint
Posted: 03 Dec 2012, 13:04
by uhans
non problem with downloading !!! it's in XSI - I can't find the plugin/toolbars after insalation, where I can find this toolbars in XSI
Re: mesh paint
Posted: 03 Dec 2012, 13:15
by Rork
It's under the "Edit" dropdown. Rightside menu bar, above the "Freeze" etc. button.
Hope that helps.
Re: mesh paint
Posted: 03 Dec 2012, 13:37
by uhans
Rork wrote:It's under the "Edit" dropdown. Rightside menu bar, above the "Freeze" etc. button.
Hope that helps.
Thank You!!!!!!
Re: mesh paint
Posted: 04 Feb 2013, 01:21
by Falam
I'm having a bit of an issue with Mesh Paint. I want to paint the cylinder along the inner or outer edge of my object as seen in the image. In the example video where rivets were painted on the plane things worked fluidly, maybe because it's a broad surface (
broad as in big area). Things are not working so fluid on my object, I froze the scale on the cylinder and painted, that didn't work, I painted the cylinder at regular size and using meshPaint controls to change the size, that isn't working as I expected either. My theory is, maybe the edge of the object I want to paint onto is too narrow, not as broad (hence the broad example used earlier) ? I hope all is understood
