Page 4 of 5
Re: Set Polygon/Edge Position
Posted: 08 Aug 2012, 18:20
by Tekano
oh think you can just put any numbers in like 000000000 etc if its just the trial you want.
so serial 000-00000000 and product key 590E1 should work.
Steve is your man for that though ;)
Posted: 08 Aug 2012, 18:25
by iamVFX
Tekano wrote:so serial 000-00000000 and product key 590E1 should work.
Yea, I thought so too. In fact before that I actually installed SI 2010 with this trick, but it's not the case now
Posted: 08 Aug 2012, 18:30
by xsisupport
iamVFX wrote:Tekano wrote:so serial 000-00000000 and product key 590E1 should work.
To activate a standalone license, you will need the actual serial number.
The installer will take anything, but the activation is a different thing.
I can look up your serial number for you, if you want to PM me (I'd need your full name, or your account name, so I can search and find the info).
thanks
Posted: 08 Aug 2012, 18:34
by iamVFX
xsisupport wrote:(I'd need your full name, or your account name, so I can search and find the info)
Which account? Where I should be registered? What sort of info you supposed to find?
Posted: 08 Aug 2012, 18:41
by Tekano
yeah its a trick question in the install procedure - as far as I'm aware you should be able to install without activation. once installed then dont activate and just run Standalone in trial mode?
Posted: 08 Aug 2012, 18:58
by xsisupport
iamVFX wrote:xsisupport wrote:(I'd need your full name, or your account name, so I can search and find the info)
Your Autodesk account. If you purchased a license of Softimage, then there is a serial number on record for you, and you can use that serial number to activate Softimage.
If you don't have a license, then it appears that your 30-day trial is over (otherwise, Softimage would give you the option of "trying for 30 days" or "activating").
Posted: 08 Aug 2012, 19:01
by iamVFX
xsisupport wrote:If you don't have a license, then it appears that your 30-day trial is over (otherwise, Softimage would give you the option of "trying for 30 days" or "activating").
It physically not possible since I formatted the drive and installed the system a few weeks ago
Posted: 08 Aug 2012, 19:06
by iamVFX
I used trial version of Softimage 2010 for few days and it worked
Posted: 08 Aug 2012, 19:18
by xsisupport
iamVFX wrote:xsisupport wrote:If you don't have a license, then it appears that your 30-day trial is over (otherwise, Softimage would give you the option of "trying for 30 days" or "activating").
Well, unfortunately the trial period is considered expired, and there's no way I know to get it back, short of installing on a different PC.
Posted: 08 Aug 2012, 19:20
by iamVFX
Then why Softimage 2010 is
working? I installed it right now with no problems. They use different licensing systems?
Posted: 08 Aug 2012, 20:01
by xsisupport
iamVFX wrote:Then why Softimage 2010 is
Same licensing systems, but different licenses.
Trial is a special version of a standalone license, and it is virtually impossible to reset.
That 2010 is running with a permanent license (I don't see "Trial" in the title bar). I can't tell if it is standalone or network. I'm going to guess network. Usually a hard drive reformat would require you to reactivate the license, but maybe you got lucky there.
