Page 1 of 1
water simulation help!!!
Posted: 13 Sep 2013, 20:01
by M3D
hello guys
I have to create an animation of water, with Softimage (ice)
the water enters in a filt, simple, but ...
I can not fill all the spaces of the filter.
I tried with flow along curve, to create the course but the water flow stays the same (size, diameter).
I can not fill all the spaces,
the water must fill the entire filter.
can you help?
plugin, ice compound? ....
thanks
Re: water simulation help!!!
Posted: 13 Sep 2013, 22:11
by Hirazi Blue
What are you currently using? Lagoa?
Could you show us some screenshots of your setup so far and especially your ICE Tree(s)?
Posted: 14 Sep 2013, 09:21
by M3D
I did a test with basic emission and flow along curve,
the flow of water, the diameter, is always the same, does not conform to the filter \ cylinder,
I do not know what to use, do not know well water ice particles for simulation,
I ask for help
Posted: 14 Sep 2013, 16:15
by Hirazi Blue
What you're probably looking for is the "Emission Resolution" and the "Number of Points Created" described on
this page of the documentation
Posted: 15 Sep 2013, 12:41
by M3D
ok, thanks, but my problem is not the number of points created,
the filter, has different diameters, the water must enter and expand, then shrink.
if I create a flow of water with lagoa (or basic emission) the flow is a unique diameter.
if I create a flow along curve, the diameter does not change, the water follows a path but does not expand as it should.
Posted: 17 Sep 2013, 16:16
by M3D
ok, use Lagoa, it seems to me the best solution,
only problem, I want to create flow along curve, but as I do with Lagoa??
help!
