QuickMerge
Posted: 28 Sep 2013, 16:45
quickly made quick merge tool ..
Usage -
Run the script then select objects / groups that you want to be included in the merge operation and right click when you have everything you want.
By default the merged mesh's center SRT, name, and parent will be based on the first object selected, to override this hold ctrl while left clicking on any object to use its SRT values, hold shift while clicking on an object to use its name, and Ctrl+Shift to set the parent of the merged mesh to the parent of the object clicked. Middle click to select a parent object directly.
Any object picked as a name / srt / parent shouldn't be added to the merge, click on them normally if you want them included aswell.
http://www.youtube.com/watch?feature=pl ... zOU#t=1479
Usage -
