Page 1 of 1
Script Viewport Capture, how? [SOLVED]
Posted: 19 Oct 2016, 22:08
by Draise
I have developed a workflow with some passes from OpenGL. But, I would like to automate it. I have resolved to render out from the Sequencer camera and log the In/Outs for editing and composing later - but I want to automate the process of switching the passes then rendering out the capture - hopefully by script.
But the only script I see SI logging is the following:
Which opens up the View Port Capture panel - where I can setup things manually then render things out.. but I want to automate it via script.
I know how to open up the panel and switch passes automatically... but the manual dependance on the viewport Capture panel is a bit of a bottleneck.
How do I do this?
Re: Script Viewport Capture, how?
Posted: 20 Oct 2016, 14:49
by luceric
Posted: 20 Oct 2016, 18:58
by Draise
Thanks for that. Silly me for not googling it.
Here is a two shot test script I built from those guidelines. Works like a charm!
##Set Pass and viewport settings
#Application.SetCurrentPass("Passes.S01_AO")
#Application.SetValue("Views.ViewC.SequencerCamera.camdisp.hqvenable", True, "")
#Application.SetValue("Views.ViewC.SequencerCamera.camdisp.rtshadowenable", False, "")
#Application.SetValue("Views.ViewC.SequencerCamera.camdisp.rtaoradius", 0.18, "")
#Application.SetValue("Views.ViewC.SequencerCamera.camdisp.rtaoscale", 0.02, "")
#Application.SetValue("Views.ViewC.SequencerCamera.camdisp.rtaointensity", 1.75, "")
#Application.SetValue("Views.ViewC.SequencerCamera.camdisp.rtaoblursamples", 0, "")
#Application.SetValue("Views.ViewC.SequencerCamera.camdisp.multisampling", 0, "")
from siutils import si # Application
from siutils import log # LogMessage
from siutils import disp # win32com.client.Dispatch
from siutils import C # win32com.client.constants
import win32com.client.dynamic
# Get the current frame
fc = si.ActiveProject.Properties("Play Control").Parameters("Current").Value
# Set the capture options
oViewportCapture = si.Dictionary.GetObject("ViewportCapture")
# Capture a 1-frame sequence
start = oViewportCapture.NestedObjects("Start Frame")
win32com.client.dynamic.Dispatch(start).Value = 5 #fc for current frame
end = oViewportCapture.NestedObjects("End Frame")
win32com.client.dynamic.Dispatch(end).Value = 8 #cf for current frame
# Specify the output file name
# For scripted captures, the output file format is determined by the extension
name = oViewportCapture.NestedObjects("File Name")
win32com.client.dynamic.Dispatch(name).Value = "\\\\RATOONZ3D-PC\\Projects\\3D MINI-PROJECTS\\Huellacas\\Render_Pictures\\RENDER\\S01\\S01_AO\\S01-All_AO_.png"
#Image scale W
scalex = oViewportCapture.NestedObjects("Width")
win32com.client.dynamic.Dispatch(scalex).Value = 800
#Image scale H
scaley = oViewportCapture.NestedObjects("Height")
win32com.client.dynamic.Dispatch(scaley).Value = 600
###Extra settings:###
#Image OpenGL AA
gl = oViewportCapture.NestedObjects("OpenGL Anti-Aliasing")
win32com.client.dynamic.Dispatch(gl).Value = 0
#Image Alpha
alpha = oViewportCapture.NestedObjects("Write Alpha")
win32com.client.dynamic.Dispatch(alpha).Value = 0
#Launch Flipbook
launch = oViewportCapture.NestedObjects("Launch Flipbook")
win32com.client.dynamic.Dispatch(launch).Value = 0
# No dialog
si.CaptureViewport( 3, False );
########### Take another shot
# Capture a frame sequence
start1 = oViewportCapture.NestedObjects("Start Frame")
win32com.client.dynamic.Dispatch(start1).Value = 5 #fc for current frame
end1 = oViewportCapture.NestedObjects("End Frame")
win32com.client.dynamic.Dispatch(end1).Value = 8 #cf for current frame
name1 = oViewportCapture.NestedObjects("File Name")
win32com.client.dynamic.Dispatch(name1).Value = "\\\\RATOONZ3D-PC\\Projects\\3D MINI-PROJECTS\\Huellacas\\Render_Pictures\\RENDER\\S01\\S01_AO\\S01-All_AO_.png"
#Image scale W
scalex1 = oViewportCapture.NestedObjects("Width")
win32com.client.dynamic.Dispatch(scalex).Value = 400
#Image scale H
scaley1 = oViewportCapture.NestedObjects("Height")
win32com.client.dynamic.Dispatch(scaley1).Value = 200
# No dialog
si.CaptureViewport( 2, False );
